Originally Posted by craigvince
That's great! Congratulations. You're almost there.
I always thought you had to pass the written before you could solo..... My memory must be getting foggy with old age  .
Thanks a bunch. I was nervous beforehand. I told the examiner the wrong birth date the first time. He mentioned to his assitant that they should put some more bags in the testing room for when they throw up. At first I thought he was kidding, but I wasn't sure
As I understand it (I'm sure someone else can explain better, FAR 61.87) you don't have to pass the Private Pilot Airplane written test to solo. Your instructor provides you a test that quizzes your knowledge of the applicable sections of 61 & 91 and the operational procedures for the airport you're soloing at in addition to the operation and limitations of the airplane.
Direct from the student pilot guide "When to Take the Knowledge Test... For optimum benefit, it is recommended that the knowledge test be taken after the student has completed a solo cross-country flight."
So I guess you are getting old
