Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 04-04-2008, 03:07 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Garmin 496 - what is this annoying line?
I have been digging into the fine points of my 496 and somehow got a biug ugly line to display that I cannot get rid of. I think it is of a series of flights the previous owner made, so I have looked at flights and in tracks but do not know what I did and how to un do it.
Anyone know what's up with this? Thanks.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 04-04-2008, 03:28 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Usually, the purple line is the flight plan line - have you gone in and checked to see if there is an active flight plan? that's the only guess I've got.....sorry....
You could send a PM to MBurch if he doesn't answer here - I've found he knows a fair amount about the unit.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-04-2008, 03:35 PM
Geico266's Avatar
Geico266 Geico266 is offline
Paul has it right, that is your flight plan line. Click on page until your destination page comes up (I think that is what they call it) click menu and then "Cancel Active" or "Deactivate". Unless of course (pun intended) you intend to fly there!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 04-04-2008, 04:48 PM
Bubblehead's Avatar
Default Traceback!
Well, you guys were close, and what you said helped me find the culprit. It actually was playing back a previous flight track!
Thanks.
Q: What would I do without this forum?
A: I guess fly around with an ugly old line on the screen!
Old 04-04-2008, 04:58 PM
Geico266's Avatar
Bubblehead, what do you expect for free advice? Close is good!
Old 04-04-2008, 05:07 PM
Bubblehead's Avatar
Well, at least I got my money's worth!
Old 04-06-2008, 02:40 PM
mburch's Avatar
mburch mburch is offline
Originally Posted by Bubblehead View Post
Looks like the bearing line to me - it's a line that is always drawn from your present position to the next flight plan waypoint. If you don't want to see it anymore, go to the map page, press Menu, choose "Set Up Map", navigate to the tab marked "Line", and change "Bearing Line" back to Off.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 04-06-2008, 06:04 PM
Bubblehead's Avatar
Thanks, Matt. Generally I think that would be the answer but it turns out I had turned on playback of a previous track. Once I turned that off the line went away and all is well again.
Old 04-06-2008, 06:16 PM
snowbird snowbird is offline
I didn't even know you could do that. I think there is a market for a "X96 for Dummies" kind of book with all the features that are not in the manual. For example I don't think the manual covers how to "rubber band" a route.
Old 04-06-2008, 07:17 PM
mannanj's Avatar
mannanj mannanj is offline
Default "Rubber Band"
Not to hi-jack the thread-----is it possible to "rubber band" a route on a 3-496? If so, how?
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
