Old 04-02-2008, 08:25 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Wing mounting/fitting question?
I am a few weeks away from fitting my RV-7 wings to fuselage and wanted some input from those who have passed this way before me.
1. If the rear spar is trimmed per the plans is there interference with the AN470 rivet on the fuselage right about the rear spar attach which will cause a forward sweep to the wings?
2. In general did you have to trim more of the spar away to prevent any forward sweep?
I just don't want to install, uninstall trim and then re-install the wings if I can prevent it.
Any insight would be appreciated.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 04-02-2008, 08:30 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Paul-
I just did this a few weeks ago. I put a flush rivet where the AN470 rivet was supposed to go above the rear spar when I originally build the fuse. If that wasn't a flush rivet, I would of had some interference issues. I needed to trim about 1/32 - 1/16" off the rear spar fork (fuse side) to cause my sweep to come back. The fork was hitting the flange of the wing rib. I didn't have to trim any of the wing portion of the wing spar, other than what was called out in the drawings.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 04-02-2008, 09:44 PM
cjensen's Avatar
cjensen cjensen is offline
I had a 470 rivet in that spot, and had to drill it out due to interference. I put in a Cherry Max flush rivet to replace it.
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 04-02-2008, 10:12 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default Which rivet?
This is good info - can someone post a picture of the rivet under discussion? Is it the rivet directly above the rear spar cutout in the side skin? Looks like there are 2 there, one directly above and another further up.
I'm coming up on the point of putting the rivets in and I'd love to get the flush rivet in now.
Thanks for any help,
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 04-02-2008, 10:38 PM
Rivethead Rivethead is offline
I had no interference but it was close.
Old 04-03-2008, 07:54 AM
cjensen's Avatar
Here's a pic of the rivet in question.
Chad Jensen
Old 04-03-2008, 10:35 AM
Lars Lars is offline
RV-7 QB wings & fuse. Trimmed the aft spar to the plans. The rivet just missed on both sides. As in, by a couple of thousandths
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 03-15-2009, 11:02 PM
jimgreen jimgreen is offline
I've just fitted my wings and have a clearance issue with that rivet. At the moment I have 1/4" of fwd sweep on each side. I have pulled the wings out an inch or so and filed the heads flatter but it didn't seem to make enough difference. May have to trim the rear spar a little. I don't like to repeatedly remove the wings due to the possibility of scratching the spar or dinging the lower fuse skin. I'm tempted to just leave it with slight fwd sweep.
Old 03-16-2009, 06:18 AM
RVRC's Avatar
RVRC RVRC is offline
Default 1/4" forward sweep
I just drilled my rear spars on Saturday and I had a 1/4" forward sweep. I, too, didn't want to remove the wings to file down the 1/8" bars. I talked with my Tech Adviser and we concluded that it wouldn't make much difference. Drilled them suckers and moved on! YMMV!
RVRC
Robert Cutter
RC & Moonpie
RV7 slider - First flight 5/3/14
Over 500 hours on the Hobbs now
N516RC
Old 03-16-2009, 08:29 AM
allbee allbee is offline
Great, I have that rivet there as well. Now, what size Cherry Max did you use?
thanks
