Old 04-02-2008, 04:18 PM
Michael Brown Michael Brown is offline
Default To Lock or Not To Lock
I am about to order the deluxe gas caps from Vans. I can't decide whether to buy the locking one or the non-locking. I am thinking of getting the locking with the rising cost of fuel, but on the other had thats something else to fail. This plane will be hangered. What do you guys think?
Michael Brown VAF #1458
Elkton, MD
Building RV-7
N227MB (Reserved)
Empennage Done
Wings Under Construction!
Old 04-02-2008, 04:59 PM
bergroup bergroup is offline
I don't see this as becoming a serious problem in spite of the rising cost of fuel. Tampering with an aircraft is a FEDERAL offense that most would-be thieves don't want to deal with. I'm sure there will be instances of Avgas theft, but if you plan on having your plane in a locked hanger the chances of getting ripped off are slim to none.
Old 04-02-2008, 05:04 PM
Jamie's Avatar
Jamie Jamie is offline
Completely a personal decision for you. That's what's so great about these projects -- make it your plane. I would say you can't go wrong either way. Just be sure not to lose the key!
FWIW, the standard fuel caps are fine.
Old 04-02-2008, 05:18 PM
I am more concerned about failure of the lock and not being able to put fuel in my plane. I am in trouble if I lose the key, as I am sure the ignition key will be with it.
Elkton, MD
Building RV-7
N227MB (Reserved)
Empennage Done
Old 04-02-2008, 05:55 PM
Default Duh....
Good Point!
Elkton, MD
Building RV-7
N227MB (Reserved)
Empennage Done
Old 04-02-2008, 06:23 PM
Default Don't Lock
Every time I configure the plane for a short race (less than 300 miles) I have to remove the tip tanks. In order to do that I have to get the unburned fuel out of them. I unscrew the drains and the fuel streams out so fast that if I have more than 5 galons left in them it requires some quick action to get the drain plug back in. If someone is interested in stealing your gas they wouldn't care if your caps were welded on. The operational problem potential is increased with no benefit.
Bob Axsom
Old 04-02-2008, 06:45 PM
JHines JHines is offline
Good points have been made that locking caps won't prevent fuel theft.
They should still help prevent vandalism (e.g. putting foreign substances INTO the tanks) and theft of the caps themselves.
Jonathan Hines
Charlotte, NC
Old 04-02-2008, 06:46 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Always have at least two sets of keys when going cross-country.
Old 04-02-2008, 07:06 PM
TSwezey TSwezey is offline
If I remember correctly the openings for the locking caps are smaller and harder to see your fuel level while filling.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 04-02-2008, 07:45 PM
captainron's Avatar
captainron captainron is offline
Back in the 70's, I think, Saturday Night Live introduced The Coneheads. The next day, our local airport had several airplanes missing their spinners! You have to be able to read the warning signs on the airport fence, or even care that you might be Federally prosecuted (or even locally prosecuted!) before you'll not vandalize an aircraft.
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
