Old 04-02-2008, 04:11 PM
jetblackaircraft's Avatar
jetblackaircraft jetblackaircraft is offline
Default Gear leg fairings/fillets
Does anyone know of any companies that make better gear leg fillets? The ones supplied with the Van's kits leave a bit to be desired. They require a lot of finish work and are kind of heavy as far as composite parts go....
Old 04-02-2008, 04:15 PM
Transporter Transporter is offline
Default Fairings, Etc.
See http://www.fairings-etc.com/
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 04-02-2008, 04:20 PM
TSwezey TSwezey is offline
Originally Posted by Transporter View Post
Their's are a 100 times better than Vans! I don't know why Van's even bothers sending the junk they send when it comes to fairings!
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 04-02-2008, 11:54 PM
rv4dude rv4dude is offline
Thumbs up
Real nice fellow and good products!
Old 04-03-2008, 12:05 AM
N941WR's Avatar
N941WR N941WR is offline
Which RV do you have?
No one makes them for the RV-9. RV-9A yes, but not the -9.
I've tried to make the -7s work but they didn't some out so go good and need to be remade.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-03-2008, 12:23 AM
N916K's Avatar
N916K N916K is offline
I used the RV-7 top ones. Had to cut off the part that touches the gear leg fairing and add some fiberglass. In the end it was easier that starting from scratch.
The lowers on mine are attached to the wheel pants. You can make those without any tooling.
Cam
Cam
Santa Ana, CA
RV-9 at KFUL
Old 04-03-2008, 09:33 AM
Default Wing tips?
Thanks! What about different wing tips? Any options there?
Not for my airplane, just seeing if there's a market for this stuff. Trying to expand my product line.
Currently I'm making carbon fiber UAV (unmanned air vehicle) parts and would like to get into the homebuilt fullsize market.
Here's a couple of pics of a wing I've made for a UAV:
The 28" long 12" chord wing section weighs only 12oz and when placed between two saw horses 24" apart it will hold over 50lbs in the center.
So, using the same process and materials (possibly fiberglass instead of carbon fiber) I would like to look into making some fairings for Van's aircraft. Possibly even some wingtips if there are not many options there.
I know Van's airplanes have incredibly short takeoff and landing anyway, but some modified wing tip shapes might help shorten takeoff and increase cruise speed.
I'd be curious to know what you guys think.
Mike
Old 04-03-2008, 08:29 PM
macrafic's Avatar
macrafic macrafic is offline
Aero-Strategies Unlimited (http://www.aerosu.com/part3.htm). I bought a rotating fuselage stand from a guy who had finished his RV. He had originally bought fairings-etc fairings and, while finding them MUCH better than Vans', was still not satisfied. Ordered some from Aero-Strategies, and liked them even better. I haven't reached that far yet, so am simply relaying one man's opinion. Like everything else on our planes, its nice to have options!
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 04-03-2008, 09:07 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
From looking at the Aero-Straegies web site, the product looks just fine......
However, the products from Fairings-etc are of very high quality, and by no means cheap! I just can't grasp the "still not satisfied" statement, and then ordering the products stated above, as a replacement. I just don't see anything better about them.
L.Adamson --- RV6A
Old 04-03-2008, 09:12 PM
Default They are very easy to make
I know this is disgusting to hear but why subject yourself to these "products". These little fairings are very easy to make with modeling clay from Hobby Lobby and fiberglass. The finished product is a perfect fit. Making molds for big things like wingtips is more work but man they comeout good! The experience is priceless.
Bob Axsom
