Old 03-30-2008, 07:35 PM
rv7charlie rv7charlie is offline
Default sump fitting on parallel vs. angle valve 360's
Anyone know whether the various sumps for Lyc 360 engines are interchangeable between the parallel valve & angle valve engines?
I've got a parallel valve engine & a chance to purchase a sump off an angle valve engine (no p/n supplied for the sump).
Seems unlikely that the original intake tubes would fit, but will they? If not, are the sumps 'standardized' on inlet tube position so parallel valve tubes would be available to fit?
Charlie
Old 03-30-2008, 07:59 PM
yakdriver yakdriver is offline
The sumps are the same the intake pipes are different. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 03-30-2008, 08:44 PM
Excellent! I'll try to close the deal knowing that by buying the right tubes, I'm good to go.
Charlie
