I have quite a few hours on my plane now with the soft seals in the wheel pants. I used two types of baffle material for the seals. The soft type of baffle material did not last very well. The baffle material, as supplied in Van's kits, seems to wear quite well.
When I first installed the seals I did show a slight increase in speed compared to my normal test plane. However with the wear of the one type of baffle material that difference quickly went away. The seal must be tight or there is no benefit. Bob Axoms idea regarding moving the seal to a lower point on the tire has merit but it probably means that these additions should be easily removable as they certainly would not be suitable for my grass strip or normal flight operations. Also the baffle seals freeze to the tires very easily which means that I would have to remove my wheel pants for a greater part of the year than I would normally, for cold winter conditions.
I am going to do some more experimentation here this year but I would not consider this type of modification unless you are trying to get the last little bit of speed for competition reasons.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
