Has Anyone used or considered Basotect UL or Basotect foam from BASF.
Seems ideal for use in RV at 3/4 lb per 12 sq ft of one inch thick Melamine foam insulation.
Would like to get a purchase source for the UL (ultalight product)
A product by BASF is very light (0.6 lb per 12 sq feet ) is called Basotect. another varient called Basotect UL is made for Boeing. Any comments on source of material or has anyone used this productr (melamine foam)?
Very impressive sound deadening properties with good thermal insulation
