01-26-2005, 05:44 AM
Originally Posted by txaviator
Home Depot sells it. Go to the 'caulk' aisle, and it is there. For whatever reason it is always on the top shelf, no matter what Home Depot I have been in. I cannot recall the names (they sell 2-3 brands) but it is labeled as 'Fire Barrier Caulk'.
Sounds like the same stuff noted above. If you click on the link, you'll see "3M Fire Barrier Caulk". If so, that stuff will not hold up to the heat of the engine compartment. Maybe you can check the label? It needs a continuous heat rating of at least 400 degrees F.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
02-22-2005, 06:31 AM
Follow-up
As an exclamation point to my thread, check out the story on Aero News Network, February 22, 2005, lead story. The link is: http://www.aero-news.net.
This drives home the point regarding firewall integrity.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
02-22-2005, 10:37 AM
Forum Peruser
Firewall Integrity
Good post, Randy. I was going to post the link to the Aero-News article, but I see you've already done it. Sounds like they've done their homework See www.epm-avcorp.com
Don Hull
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
02-22-2005, 11:21 AM
Need better link
Can someone post a better link to the story on Aero News. The lead story there is another wet-n-slurpy to Cirrus.
BC
02-22-2005, 11:26 AM
BC
http://www.aero-news.net/index.cfm?C...-b3dc6817cdfb&
Brian
02-22-2005, 12:12 PM
I'll be darned
I'll be darned. That's MY EAA chapter!!! I should go to a meeting once in awhile.
02-22-2005, 02:32 PM
Forum Peruser
Small World isn't it, Bob? How about that? By being a member of these forums, you found out what your local EAA chapter is doing! Now that's communication!
Don Hull
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
03-05-2005, 02:00 AM
Firewall Sealant
PRC-DeSoto (a division of PPG) makes three types of high temp firewall sealant. Go to www.ppg.com/prc-desoto/main.asp. Select "PRC and Pro Seal Aerospace Sealants." That will take you to another page. Select "High Temperature and Firewall." This will take you to the page that has the three sealers listed. They are P/S 700, PR-812, PR-1995. Also listed is a product called Korotherm. This is a high temp primer. You do not need it for your RV.
The normal operating range of each of the sealers is from -65F to +400F. They will withstand a 2000F flame for 15 minutes with no penetration.
I have used both the P/S 700 and the PR-812. They are a little bit difficult to use but the protection they offer is invaluable.
These sealers are not available over the counter. Your local FBO can help you aquire the product.
They have a shelf life so don't purchase until you are ready to use it. They come in quanties as little as 1/2 pint.
One final note: These sealers are not cheap. They are very good however. Download and read the data sheets. These will show you the tests that these sealers underwent.
03-08-2006, 11:37 AM
Bio-Therm 100
This is the stuff that www.epm-avcorp.com include in there firewall penetration kits. They sell tbes of it separately. I just orderd the SS heater vents and a tube of Bio-Therm 100 from them. One thing they mentioned was that the product is not intumescent, which means it does not expand when heated.
http://www.biofireshield.com/data/data100.pdf
Andrew Rayhill
RV-10 40078
Phoenix
