If you are installing the MT governor on a Superior IO-360 it appears that the bracket does indeed poke up about 30 degrees above the horizontal. This means the control arm is now in the wrong place. You therefore will need to cut the wires on the six bolt heads that secure the control arm mechanism, loosen (do not remove) the bolts a little and then turn the control arm mechanism so that the arm points up at around teh 2.00 position,. It may be difficult to reolve the geometry, but the cable should be able to push the arm to the fully fine position.
the link shows the position of the bracket but with the control arm as supplied by MT -
http://www.gapilot.co.uk/build/2005/dec05/03dec05.htm; Jim's picture shows the final result with the control arm suitably adjusted.
I hope that is all helpoful to a few more folks.
Chris
