What fuel injection do you have?
What fuel injection setup do you have? AFP? If so (that is what I have, too), you may need to clock the intake servo 90 degrees on the sump. On the AFP servo, the mixture and "throttle" arms are on the same side. If you rotate it, both of them can be oriented to the bottom of the sump. Then you can get appropriate throws without using that crazy bracket stuff that Van's provides.
Sorry if you don't have AFP and something else...probably not a lot of help.
Rob Johnson
Bloomington, IL
RV-7 N826RC - sold
1945 Piper J3 Cub - sold
RV-10 - wings with fuselage ordered
https://www.rv-builder.com
Reason: added clarification on bracketry
