Old 03-25-2008, 04:32 AM
NYTOM NYTOM is offline
Default Electrical Connectors
What are some of the way you guys connect the wiring at the trim servo motors or other electrical devices? I'm thinking some kind of small weatherproof multi pin plug but can't seem to find any reference in the forums or searching through the av catalogs. I've found the computer type multi pin type but I'm sure there not weatherproof. Or do you just use individual connection crimp-on's and seal them up? The nav lights aren't the problem, its those tiny wires coming from the servo.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 03-25-2008, 07:19 AM
Transporter Transporter is offline
Default Aeroelectric Article
See
http://www.aeroelectric.com/articles.../macservo.html for one way to wire the MAC/Ray Allen trim servos using D-sub connectors.
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 03-25-2008, 07:20 AM
DGlaeser DGlaeser is offline
Default D-Subs
I used D-Sub connectors. On the elevator trim, I used a connector with solder cups and soldered the small wires. In other areas I crimped on d-sub pins. I found that using the machined pins with the small wires it's tough to assure a good attachment, using the stamped pins works better.
No matter what you use, working with the small wires is a pain.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 03-25-2008, 09:07 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by NYTOM View Post
What are some of the way you guys connect the wiring at the trim servo motors.......
This "quick disconnect" system seems to have worked so well on my -6A electric aileron and elevator trim system that I fabricated the same arrangement again. When the elevator is attached to the horizontal stab, the servo wires coming out of it are routed to and plugged into a mating 5-pin receptacle that is located underneath the empennage fairing and mounted on the aftmost bulkhead shown. This particular 5-pin male/female connector does require a bit soldering to secure those tiny wires but is cheap and simplifies installation and removal of the control surface as far as trim wiring is concerned.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 03-25-2008, 09:23 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I like to use just the D-sub pins, without the shell, and cover with shrink tubing.
Small in size, low in mass (vibration issues), reliable connection, and still removable by slicing off the shrink tube.
IIRC, this is another of Nuckols ideas.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-25-2008, 03:18 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up Conxall Mini-Con-X connectors
Tom... these Conxall connectors are not too expensive, are weatherproof and locking.
The Mini-Con-X are the appropriate ones...
http://www.alliedelec.com/Images/Pro...le_3000061.pdf
They seem to be a nylon injection molded version of the way expen$ive Mil-Spec connectors.
The 6 pin one is ideal for servo connections, and can be mounted just like the DIN connector above (which is not very weatherproof......)
They can be bought at most of the big name electronic on-line suppliers... link above is to Allied... I'm fairly sure Mouser also has them...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-25-2008, 03:22 PM
Mathew Sharp's Avatar
Mathew Sharp Mathew Sharp is offline
I've got m/f nine-pin Amp style connectors (cannon plugs) as well as 16 pin versions. We use these on our instruments. I can sell some for pretty cheap if anyone is interested.
Electronics International Inc.
Sales/Support
63296 Powell Butte Hwy
Bend, OR 97701
www.buy-ei.com
support@buy-ei.com
877-318-6060 Ext 113
Old 03-25-2008, 08:30 PM
Talking Problem solved
I knew you guys would come through. I was thinking of the D-subs and was going to give them a shot but was worried about them not being waterproof and rusting in the wing. It's pretty nasty up here in the Northeast on aircraft.
I never even thought of trying to eliminate the rusting part. Gil I'm going to try a couple of those mini-con-X connectors. Its pretty much what I was thinking about but didn't even know they existed. Gentlemen I thank You.
If this site ever goes away I'm gonna have to take the pipe.
Tom Norwood
TMX-O360. Phase 1
Old 03-25-2008, 10:11 PM
briand's Avatar
briand briand is offline
Default Yea But............
How do you get that "sorta fat" connector through the little hole between the two HS609s rear spar reinf. bars?
Old 03-26-2008, 10:38 AM
Rick6a's Avatar
.......How do you get that "sorta fat" connector through the little hole between the two HS609s rear spar reinf. bars?
Radius to smooth transition.
YMMV.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
