Old 03-24-2008, 12:48 PM
rfinch rfinch is offline
Default Good crimping tool?
Van's preview plans and manual talks about crimping....for the RV-9 on p. 5-21 it describes the type of crimp desired--where just one side of the barrel is indented--and contrasts that with a lesser quality crimp which crushes the whole barrel into an oval.
Good. What type of crimper will produce the desired, better quality crimp?
Ralph Finch
Davis, N. California
RV-9A QB Log
Old 03-24-2008, 01:49 PM
rvtach rvtach is offline
Get you one of these http://www.harborfreight.com/cpi/cta...emnumber=93977 for crimping PIDG type connectors. They can be found on sale for $10 at H-F.
This tool http://www.harborfreight.com/cpi/cta...emnumber=36411 will do what Van's says but the ratcheting crimper above makes a better crimp.
Hope this helps.
Jim McChesney
Tucson, AZ
-7A Finishing Kit
Old 03-24-2008, 01:53 PM
Transporter Transporter is offline
Default Aeroelectric Connection
See the crimper recommendations at:
http://www.aeroelectric.com/articles...ng_Started.pdf
Good hunting,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 03-24-2008, 02:06 PM
rleffler's Avatar
rleffler rleffler is offline
Here's the tool that Bob Nuckolls recommended in his seminar.
AMP 59250 Red Blue Certi-Crimp T-Head Hand Crimper
There are usually several of them on Ebay, but I didn't see any when I did a quick search. I was able to purchase one for about $80 last December.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-24-2008, 03:38 PM
craigvince's Avatar
craigvince craigvince is offline
Cool
Hope this helps.
Not sure I'd trust my electrical system with any tool from Harbor Freight. Don't get me wrong, I have a lot of HF tools, just not for my electrical. Some things are worth getting right the first time, every time.
Old 03-24-2008, 03:41 PM
pmccoy's Avatar
pmccoy pmccoy is offline
Default Expensive
I just did a web search for these. Ebay has a couple used for $140 & $190 + SH. I also found a site selling them new for $990!
YIKES! This wasn't in the budget.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
Old 03-24-2008, 04:00 PM
tmbg's Avatar
tmbg tmbg is offline
man up and buy the AMP tool. There really is no comparison.
Similarly, if you're gonna do any amount of avionics harness work, spend the money and get a DMC AFM-8 pin crimper and the positioners.
Ian
Old 03-24-2008, 05:07 PM
rleffler's Avatar
Agreed..... After taking Bob's seminar, I purchased both. They are hot items on Ebay. Just start shopping early and pass on those auctions that get out of line. I got both of these tools for about $80 each.
Pricing is probably directly proportional to the sense of urgency. I don't need either for awhile, which is probaly why I got such deals. If I needed them asap, I probably wouldn't be able to find them at a reasonable price.
Bob Leffler
Old 03-24-2008, 05:14 PM
AMURRAY's Avatar
AMURRAY AMURRAY is offline
Default AMP 58433-3
I use the AMP 58433-3. It does the same thing the 59250 does, plus it does the yellow crimps. Also has interchangeable jaws for coax.
http://www.chiefaircraft.com/airsec/...alCrimper.html
Aaron
RV6 built and flying
Bearhawk Patrol plans purchased
