I'm quite happy with my A210. The display is bright and easy to read, and I use the dual-watch function much of the time to monitor Flightwatch frequencies while listening for other traffic on Air-to-air and the like. The memory capability is huge, but I have to be honest - I haven't taken the time to store more than a couple of frequencies, as it's my #2 Comm and I just haven't had the need. I can't comment on the intercom, as I don't that enabled (I have a full audio panel with its own intercom).
I upgraded from the A200, which is a great radio. The 210 appears to pull in signals a bit better using the same antenna I had with the 200. I upgraded mostly because I liked the way the 210 looked, the new display, and the ability to monitor another frequency. No, it is not quite as good as an SL-40, but I couldn't' justify the money to go from a 200 to an SL-40 for what I use it for.
I think that for a budget, single radio installation, the performance of the intercom would probably be a deciding factor between it and a cheaper A200.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
