Old 03-20-2008, 07:44 PM
szicree szicree is offline
Default How to find the center of the spinner?
In order to have a wobble free spinner, I'm supposed to first find the very center of the tip. Is there some magical trick or do I just eyeball it.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 03-20-2008, 08:19 PM
mannanj's Avatar
mannanj mannanj is offline
Default Spinner
I clamped a marker (sharp point) to a ladder in front of my spinner, tried to find dead center on the nose of the spinner, then kept adjusting the spinner with cleco clamps on the aft side of the back flange, and moving the point until there was no runout. Somehow, (just dumb luck I guess!) I ended up with a spinner that's dead on!!!!!!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 03-20-2008, 08:33 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Just Lucky....
All I remember doing was lining the back edge of the spinner up with the rear of the flange on the aft spinner bulkhead and never checked for the center of the nose. No wobble that anyone has mentioned seeing - I guess I was lucky as well!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-20-2008, 08:44 PM
Geico266's Avatar
Geico266 Geico266 is offline
We used a dial indicator on the end and get them within .005 on a side.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 03-20-2008, 09:01 PM
jthocker's Avatar
jthocker jthocker is offline
5 times with Paul's method and my eyeballs, 5 times wobble Free!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 03-20-2008, 10:17 PM
Martin Sutter Martin Sutter is offline
Super Moderator
The trick is to position the front and back plates so that the spinner contacts both at the same time when pushed against them. This can be done by adjusting the number of washers under the front or back plate. Once the position is correct the spinner is centered automatically.
You can tell when they are in the correct position when the spinner cannot be moved sideways while being pushed against the bulk heads.
On a fixed pitch prop installation you might have to use a shim under the front or back plate instead of the washers on the C.S. props.
Martin Sutter
building and flying RV's since 1988
Old 03-20-2008, 11:54 PM
az_gila's Avatar
az_gila az_gila is offline
Smile FP spinner
Martin Sutter
...or buy the metal Sensenich spinner assembly that comes pre-drilled with all of the nutplates installed...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-21-2008, 04:46 AM
Kahuna's Avatar
Kahuna Kahuna is offline
This is a cheap easy method, tested many many times.
Details here:
http://www.mstewart.net/michael/rv/s...er/spinner.htm
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 03-21-2008, 05:29 AM
sportpilot's Avatar
sportpilot sportpilot is offline
Default a little paint
This just in from the Easter Beagle.
To find the center take a small piece of alum thats good and flat. Smear a tiny bit of paint in the center. Hold the piece up to the spinner and line it up best you can sqaure on to the axis. Push the piece up against the spinner tip. That will leave a tiny spot of paint right at the apex. If that aint the center I dont know what is.
To check for wobble, tape your long #40 drill bit to something that will keep it at the same height as the paint dot. (step ladder works good). Turn the blade thru and watch the drill bit and the paint dot as they dance up and down. Adjust the spinner till you get it right. Clamp it good before you start to drill. The funny part is you wont know how good a job you did till you fire it up.
Claude Stokes (sportpilot)
Finished Building an RV-10 and a Titan Tornado 2
RV10 approaching 150 hours Vans kit 40418
See Pictures of the RV10 here. http://btconline.net/~sportpilot/RV10/boatright
Waycross, Ga. Airport KAYS
