I riveted the brackets and just remove the two socket head bolts to easily slide the pant off, leaving the axle nut and bolt undisturbed. I used two rivets per flange (8 per side) and then glassed in the flanges for added strength. Drill a couple extra holes for resin to weep in for better asdhesion. You can countersink the rivets and fill over them for a nice clean look.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
