Old 03-19-2008, 08:34 PM
ncarmon ncarmon is offline
Default Conduit or Stand-off?
Hey...
I found these and thought I would use them instead of the conduit in my wings...
http://www.terminaltown.com/Pages/Page65.html
Any thoughts? Will this work or am I missing something?
lft Wing: Landing, strobe/nav lht, pitot heat, Nav ant
rht Wing: Landing, strobe/nav lht, autopilot, MKR ant
Old 03-19-2008, 09:27 PM
SportAvServ SportAvServ is offline
Default conduit or don't duit
Conduit allows you to R&R, add or subtract wires to the wing tip, stand offs take longer fingers.
IMHO
Randy
Old 03-20-2008, 09:54 AM
fl-mike's Avatar
fl-mike fl-mike is offline
The problem with those is that the lightning holes have a rounded flange, so there's not a flat surface close to the edge of the hole to mount the standoff to. I have some, but never used them.
Mike W
Venice, FL
N164WM
Old 03-20-2008, 03:06 PM
Jekyll Jekyll is offline
Conduits, conduits, conduits. If that's not clear or desireable then I might suggest the use of conduits instead.
Whatever you decide, DON'T USE THE STICKY MOUNTS unless you have clear access to them. They will fall off at some point. Your will need to inspect them and replace them on ocassion. Use E-6000 (Shoe GOO) in place of the adhesive pads on the sticky mounts (available at Walley World and craft shops).
An RV-8A building buddy bought a kit from a builder whith the airframe completed and ready for systems. The builder used clamps on his wing runs vs conduits. Now my buddy is perplexed about how to modify what's there.
Jekyll
