Old 03-19-2008, 08:54 AM
Camillo Camillo is offline
Default Min. tube bending radius
Hi. I just installed fuel tube from Andair selector to Facet pump. I managed to do the bend beside the fuel pump, but I'm not sure it is OK. Where can I find minimum bend diameters for a given aluminium gauge?
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 03-19-2008, 02:08 PM
Transporter Transporter is offline
Default Tubing Data
See Table 9-2, page 9-19 in Advisory Circular (AC) 43.13-1B, Change 1 (ISBN 0-89100-306-1).
Although the chapter covers hydraulic systems, the table should provide the information you need.
This table also provides torque minimums and maximums for AN-818 tubing nuts.
Another reference is the "Standard Aircraft Handbook" by Larry Reithmaier (ISBN 0-07-134836-0). This book also has a table (page 183) for tubing bends and torques...bends are the same as the above reference but torque values are different; if in doubt, I'd go with the AC.
Regards,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Last edited by Transporter : 03-19-2008 at 02:50 PM. Reason: Added Standard Aircraft Handbook info.
Old 03-20-2008, 03:19 AM
skyyking56 skyyking56 is offline
Thumbs up Thanks Mike
Thanks Mike,
I was also looking for this information.
You the Man.
Jim
7A STILL on wings
Old 03-20-2008, 06:45 AM
Thank-you. I will look there.
Camillo
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
Old 03-20-2008, 08:52 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default 90 deg fitting
You can get a 90 deg steel fitting for the Facet pump. I don't have the exact part number handy but I got mine from Spruce.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
