  #11
Old 03-20-2008, 08:29 AM
flytoboat's Avatar
flytoboat flytoboat is offline
Default Deburring tight spots
Originally Posted by rv9builder View Post
Rick,
What's your secret for quickly deburring between the tiny little "fingers" at the ends of the flanges of each rib? Getting those smooth is the part that slowed me down.
Thank you,
Mark
I use a dremel tool with this accessory from Sears
http://www.sears.com/shc/s/p_10153_1...?keyword=53142
Don
VAF #1100, EAA864
-6A bought flying
Old 03-20-2008, 09:01 PM
CraigC CraigC is offline
I wonder what that bit is made up of? Wouldn't want to be impregnating corrosive material into the aluminum!
Craig C A&P/IA
Mesa, AZ RV-8 SerNo 82582
Wings/Fuse N18VA Res
Old 06-10-2008, 06:11 AM
JerryG150's Avatar
JerryG150 JerryG150 is offline
Default RV-12 wing ribs
Just fluted my first rib and I think I made it worse ... can I use the seamer pliers to un-flute and start again?
"Time, be careful how you spend it ... cause it isn't going to last."
VAF #1037
Reserved N124JG for RV-12
"12 for Jerry G.
http://jerryg150rv12.blogspot.com/
Old 06-10-2008, 06:21 AM
Wes Hays's Avatar
Wes Hays Wes Hays is offline
Jerry,
I certainly had to on a few. It worked out fine. It also helps when you are tweaking them if you get a bit heavy on the fluting pliers.
I am assuming that the -12 is prepunched in the ribs and skins?
Wes Hays
Winters, TX
RV-6A Flying 900+ hrs
RV-7A Fuselage
Old 06-10-2008, 07:09 AM
JerryG150's Avatar
Default immediate response ... thanks
Wes ... ribs are prepuched to correct size in ribs and skins ... I just started my build yesterday. Very minimal deburing of holes necessary. So far, a newbie builder like myself (with a bit of help from guys like you on VAF and builders in the "neighborhood") should be able to handle it. A "repeat offender" finished his wing kit in 105 hours ... wings, flaperons, skins, everything in two weeks. I'm glad it's not a race.
I'm going to try to flute via the rib lying flat on table with flanges up so I can see what each flute adjustment does ...
Thanks again,
Jerry
VAF #1037
"12 for Jerry G.
