Old 03-18-2008, 12:55 PM
java's Avatar
java java is offline
Default QB Slider - OK to rivet fuse top skin?
Getting to the point where I need to start working on my canopy. I hope to have all the work done mounting the rollbar and tweaking the slider canopy frame, etc. so I can make "The Big Cut" and drill through plexi when the day finally arrives that it get's warm again up here.
I've left the top skin just behind the baggage compartment clecoed for now. Anything I should be waiting on further or should I go ahead with it? I have my pitch servo installed, and have my static ports in place. Not that I'll be closing anything off that I wouldn't be able to get to, but could eliminate some convenience.
Thanks.
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 03-18-2008, 01:07 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
I would do it now, Jase. You don't really want clecos getting in the way while you're trying to fit the aft skirts, whether they are the stock aluminum or fiberglass. It's not too hard to crawl back in there for whatever you might need to do later, but it sounds like you've got most everything taken care of already anyway. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-18-2008, 01:23 PM
Jekyll Jekyll is offline
I recommend riveting it first. You will be fitting the canopy to the aft skin so it should be in its final position. Also you will be drilling and temporary fitting the aft slider rail. It is best if the skin is secure for this.
Jekyll
7A slider, canopy done
Old 03-18-2008, 02:27 PM
pierre smith's Avatar
Default A couple of things..
....to do, Jase. Put your wiring for the rear nav light in the fuselage and also attach the shoulder harness fittings and the cables. The electric trim wires can also be run now and secured with the excess wrapped. It's much easier doing it from over the sides. Don't forget the rudder cables and their grommets in the bulkheads.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
