03-18-2008, 05:49 AM
Catto prop maintenance
I've got a Catto 3 blade with a small nick.
I'm assuming sand & fill with some epoxy/filler mix, but what epoxy & what filler.
I've emailed Catto several times asking for advise about fixing the nick with no response.
Anyone done this, have any advice, or been able to get a response from Catto on it?
Steve Brown
N598SD - RV9A second owner
O-320, 9:1 pistons, Catto 3 blade
KRHV - Reid Hillview airport, San Jose, CA
03-18-2008, 05:55 AM
I use the fast JB weld.
Fill the gap and wait until it just starts to set up and trim flush a sharp razor blade. No sanding needed.
Lynne
03-18-2008, 08:30 AM
Hi Steve,
I have talked with Craig about this in the past--he keeps talking about putting prop repair directions on his web site but I think he is a little busy trying to keep up with production demand.
He told me to use a high quality epoxy (I use West Systems) and if necessary a good quality filler (I used West Systems--the red colored filler--don't remember the West system #). Assuming your ding does not go down into the underlying wood core, simply fill and sand--and if you built your RV you have a great deal of experience doing that.
I got a pretty good ding at the 2007 Big Bend Ranch State Park fly in and the repair was pretty simple--I did it on the ramp the day before leaving the Ranch.
Hope this helps.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
03-18-2008, 01:11 PM
Thanks guys!
I'll probably go with the West Systems epoxy and filler because I'm familiar with it.
Steve Brown
RV9A - N598SD - Second owner
03-18-2008, 01:21 PM
Does Craig use any kind of reinforcement under the leading edge glass (perhaps a strip of flox/epoxy filler)? Or does it seem to be just a glass fabric wrap around the leading edge?
I'm thinking about how I want to finish the big prop for the radial.
Dan Horton
RV-8 SS
Barrett IO-390
03-18-2008, 01:57 PM
I have a wood prop on my ultra light. I had a nick and was told by a fella who new a lot about wood props to mix a little baking soda with crazy glue or super glue. I gave it a try and was amazed at how well it worked. It was easy to smooth and wears like iron. You have to apply it fast though because it hardens almost instantly. The whole repair took a few minutes.
Paul Tuttle
RV 8
C-FPVT
Flying.
03-18-2008, 02:06 PM
Hi Dan,
I understand from Craigs web site (search on Catto props) that he has a minumum of .25" of glass over the maple laminant core. The leading and trailing edges, per his web site diagrams, are built up even more. When I had the ding mentioned in my post above, the depth was about 3/32" into the leading edge (about 8" from the tip). It was not into the core and very easy to repair.
Reference the leading edges, you can order the prop with FAA approved edge guards which appear to be "formed" UHMW plastic tape. I now have that on my leading edges and after the latest flight to BBRSP (site of the last ding) no damage occurred. Mel has more experience/hours with this protection and can probably comment on its longevity.
db
Dave B.
03-18-2008, 02:29 PM
Dave,
Did you order the edge guard from Catto? I didn't order it with my prop and would like to add it now.
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
03-18-2008, 02:49 PM
Hi Tony,
Yes, it was ordered from Craig--cost around $80 if I remember correctly.
Best Wishes,
db
Dave B.
03-18-2008, 03:03 PM
I ordered my "prop guard" from Aircraft Spruce. Less than $50. The 2 blade kit is enough for a Catto 3-blade. It's been on there since December of '04.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
