Use Fuel Flow Transducer
Use the cheapest and lightest standard fuel float system. They don't work anyway, and can't be trusted. But install a fuel flow transducer by either JPI. Then you'll know your fuel burn, amount on board, time to exhaustion, etc. And it will interface to your Garmin 430 when you install it.
