Old 03-15-2008, 08:38 AM
PaigeHoffart PaigeHoffart is offline
Default Stock Oil Door Hinge Installation
For those of you that have a stock oil door. How did you get the hinge pin in? How did you secure it? How did you paint the hinge/door afterwards?
I'm still on the fence regarding the concealed hinge. From what I can see on the drawings, it looks like the door will not be removable if I build to plans.
Paige
Old 03-15-2008, 03:05 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
On the 7A that I built, I used the stock hinge and pin. The hinge is in a slight recess so the pin can not slide out. I left the door off the cowl during painting. I placed protective tape on the edge of the cowl as I sprung the pin up and slid it into place after painting was completed. Hasn't tried to back out in 4 years. You can use the same method and remove the pin if desired.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 03-15-2008, 04:32 PM
Thanks Roberta
