Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 03-14-2008, 10:16 AM
dwilson dwilson is offline
Default Figure ground distance from GPS coordinates?
I want to take the GPS data from my GRT data dumps and figure distance from one point to the next. Does anyone know a slick easy way to do it?
Duane
Duane Wilson
RV9A. Built, flew 1000 hours, Sold
RV10 Built, flying 330 hours so far.
Central Oregon
Old 03-14-2008, 10:23 AM
asav8tor asav8tor is offline
http://gc.kls2.com/
Old 03-14-2008, 10:29 AM
Radomir's Avatar
Radomir Radomir is offline
If you're looking for something with a higher geek factor, take a look at this site:
http://williams.best.vwh.net/avform.htm
Radomir
RV-7A sold
Old 03-14-2008, 10:41 AM
jmartinez443 jmartinez443 is offline
You can throw the Lat/Long into an excel spreadsheet and apply this formula for the distance:
d=acos(sin(lat1)*sin(lat2)+cos(lat1)*cos(lat2)*cos (lon1-lon2))
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
Old 03-14-2008, 10:57 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Constant?
Jorge... isn't there a constant missing from your formula (possibly the radius of the earth?)
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-14-2008, 11:53 AM
szicree szicree is offline
You gotta multiply that whole thing by radius to get the answer.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 03-14-2008, 11:59 AM
DGlaeser DGlaeser is offline
Default It's in there . . .
gil A
Actually no. A nautical mile is equal to 1 great circle arc minute on the earth's surface. So once you know the angle, you know the mileage
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 03-14-2008, 12:10 PM
Wouldn't this still require multiplying by 60? Additionally, Excel gives the output in radians, requiring conversion to degrees first if this approach is to be used.
Steve Zicree
Old 03-14-2008, 12:22 PM
az_gila's Avatar
Exclamation FAI formula...
Ahh... but you didn't state any units.... - and most people would use degrees for angles, not minutes ...... just like most GPS boxes output....
This is the formula the FAI use for aviation record calculations for great circle distance (from the SSA web site) - use 7-8 digit accuracy in your calculations...
Q:
What is the Great Circle Distance formula and how do I apply it to my flight?
A:
The formula is:
Distance = K ~ arccos([sin A * sin B] + [cosA * cos B * cos(X - Y)])
A = North latitude of the departure point (or Lat A)
X = West longitude of the departure point (or Long X)
B = North latitude of the destination (or Lat B)
Y = West longitude of the destination (or Long Y)
K = conversion factor from degrees to distance
= 69.09332414 (the FAI value of K resulting in statute miles).
gil A
SSA = Soaring Society of America - above lat/long assumes North America area and the use of decimal degrees
Gil Alexander
Old 03-14-2008, 12:30 PM
az_gila's Avatar
Smile Mapping
This web site will calculate great circle distances and draw a course line on a Google map/satellite picture.
It does recognize three letter airport codes...
http://www.acscdg.com/
gil A
Gil Alexander
