03-13-2008, 03:21 PM
Lord Mounts/Direction
I am using the Lord brand mounts when hanging my IO 360. Each mount has three rubber pieces. There is a gel filled insert and two "biscuits" one of which is much thicker than the other. Which biscuit is considered the hard one and which is considered the soft one. I want to make certain that I install them properly. Any help and or photos would be greatly appreciated.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
03-13-2008, 04:09 PM
The "harder" biscuit normally has a ring around it, whereas the "softer" one has no ring. The harder one goes behind the mount on top and between the engine & mount on the bottom. Easy way to remember is that the harder mount is in compression when on the ground.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
03-13-2008, 04:42 PM
Not to be a dummy but what exactly do you mean by a ring. Is that the mound that appears to be squashed down a bit? One of my lord mounts has that appearance and the other one has a smooth surface.
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
03-13-2008, 06:56 PM
Jeff, you should EASILY be able to tell which one is hard and which is the soft one.. the difference is huge.. you can try "squishing it" and you'll see what I mean
Here's a photo of the hard donut:
http://picasaweb.google.com/n777ty/P...36977792847474
Notice the "ring" in the rubber (outside surface is not "straight")
Radomir
RV-7A sold
03-13-2008, 07:39 PM
I appreciate it very much. I see the ring molded in that you are speaking of.
Just wanted to be safe rather than sorry.
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
03-14-2008, 07:16 AM
Which LORD?
I have been trying to determine the correct LORD mounts to purchase for my -9A with IO-360 engine. Checked for charts at AERO, Aircrafters, Chief as well as the LORD websites and no joy. I CAN find reference sheets for the RV-3, RV-4, RV-6 and RV-8.
If anyone can point me in the right direction it would be appreciated.
03-14-2008, 07:19 AM
J-9613-40 will work
Radomir
RV-7A sold
03-14-2008, 07:45 AM
-49's will work as well. I talked with a Lord eng as I was fortunate enough to get an unbelievable deal on a set of 4 of the J9613-49. He said they were identical to the the -40s, just one was made for Mooney (-40) and then Cessna decided they wanted some (-49).
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
03-14-2008, 08:09 AM
Originally Posted by RV8RIVETER
-49's will work as well. I was fortunate enough to get an unbelievable deal on a set of 4 of the J9613-49.
Wade, please share your source for "unbelievable deal"
