  #11
Old 03-14-2008, 07:19 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default I carry a spare fuel cap
Since the pins on mine have broken at least twice away from home. Not sure if this means that I have something adjusted wrong. Plus I carry the normal assortment of spare parts.
Old 03-15-2008, 02:31 AM
gasman gasman is offline
Default LUBE THE BIG "O" RING
WITH EZ TURN LUBRICANT.... 06-07 SPRUCE CATALOG PAGE 355. A 5 OZ TUBE WILL LAST A LIFETIME. $11.70
AV GAS WILL NOT WASH THIS STUFF OFF!!
APPLY IT TO THE THE "O" RING AND THE TAPER THAT THE RING SETS IN. YOUR CAP WILL OPEN AND CLOSE WITH EASE AND YOU WON'T STRESS THE PIN.
ADJUST THE GRIP (LOCK NUT AND DISC) SO THE CAP WILL JUST DROP INTO THE TANK FILLER COLLAR WITH JUST SLIGHT PRESSURE AFTER A COATING OF THIS STUFF.
Old 03-15-2008, 08:41 AM
az_gila's Avatar
az_gila az_gila is offline
Smile The original instructions...
Here is a link to a copy I just made of the original Vans gas cap (aka "old style") instruction sheet.
I does show the assembly fairly well, and interestingly enough, does not show the pin as a separate item....
http://home.earthlink.net/~gilalex/R...rv-gas-cap.pdf
gil A
DR - can you file this away in a good VAF location?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-17-2008, 07:31 PM
wingtime's Avatar
wingtime wingtime is offline
Default Parker -O-lube
Try lubing them with Parker O lube. That stuff is great for fixing leaks or lubing up anything that has an O-ring
Bruce Smith
Clearwater, FL
RV-7A Fuse
N27DB reserved
web.tampabay.rr.com/flrv7a
"Political correctness is tyranny with manners."
Charlton Heston
Old 03-26-2008, 10:33 AM
Robski Robski is offline
EEEEK!
I tightened my new ones with what turns out to be the locknut! Seemed to work though as both the bottom half of the cap and the locknut turned at the same time and rate!
I will have to check further!
Rob Swain.
If the good Lord had intended man to fly, He would have given him more money.
1994 RV-6: bought 2008 & improving it ever since.
