Old 03-12-2008, 09:40 AM
MacNab's Avatar
MacNab MacNab is offline
Default Cowl Saver Baffle Seal Material
I was sitting in the Chandler, AZ airport restaurant Monday eating a unhealthy, politically incorrect, but very tasty lunch, when I stumbled onto this while perusing the McFarlane Aviation catalog that was sitting on the counter.
Might be something to consider for you guys that are doing engine baffling right now or in the near future, or anyone who is considering the replacement of their worn baffle seals.
Doug
RV-6, AT-301, G-164, C-188...
Old 03-12-2008, 10:04 AM
Transporter Transporter is offline
Default Sample
I picked up a sample of this material at Oshkosh last summer. No experience with it, but it looks great compared to 'normal' baffle material. I'm a long way from cowl work but it's in a folder of prospective vendor products...
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 03-12-2008, 10:12 AM
rocketbob's Avatar
I've got regular silicone baffling in my -6 and I believe it would take tens of thousands of hours of wear to cause any cowling damage. By then the rest of the airplane will be worn out but hey, you may have pristine baffling!
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-12-2008, 11:05 AM
az_gila's Avatar
az_gila az_gila is offline
Question Material friction
Bob... I think it might be as much a vibration issue as an actual wear issue.
The Grumman baffle guru recommends that the baffle strips are sprayed with silicone spray to reduce friction.. this material seems to just do the same thing permanently.
He also uses the thinner 0.093 flexible stuff over the 1/8 reinforced to also reduce vibration transmittal to the baffles.
Their web site did not have any prices I could find for certified planes... I just got a 0 when I entered in various plane types...
gil A
PS my aluminum Grumman upper cowl is showing visible wear from previous baffle material at 1600 TT.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
