03-10-2008, 08:12 PM
Straight Restrictor Fitting
I have a Superior XP 360 engine that I am getting ready to hang. My engine has two ports, either of which can be used for the oil pressure gauge.
I intend to use the one that exits directly towards the rear of the airplane.
Van's only supplies a 45 degree restrictor fitting in the FWF kit. I am trying to locate a straight one made of steel? I don't want to manufacture my own.
Is there such a fitting available. Please advise. I can't seem to locate one anywhere.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
03-11-2008, 05:19 AM
Hi Jeff:
I searched all over for one and couldn't find one. You will find some brass ones, but no steal ones. I was resigned to use the 45 degree one from Van's. Best of luck. If you find one please let us know!
03-11-2008, 06:27 AM
Thanks for the reply. I searched on the internet from 8:00 pm until about midnight and I also had no luck. Does anyone out there in RV Land have a source. By the way did you put the 45 degree fitting in the side or rear port? Which way did you point it once installed?
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
03-11-2008, 06:44 AM
Kind of hard to tell from this photo, but this is the only one I could find on my website:
Hope that helps,
03-11-2008, 06:47 AM
Thanks for the reply. What type o sealant did you use on the fittings? Did you use a sealant and an anti-seize compound?
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
03-11-2008, 07:12 AM
I just used fuel lube. That black stuff is something superior had used before, but I couldn't remove it.
03-11-2008, 09:33 AM
Jeff,
Give me a call tonight. I made mine from info in a Bingalis book. Piece of cake. All you need is a straight fitting and an AN-6 rivet.
523-5885
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build  )
N621TR In unrestricted operation
03-11-2008, 03:11 PM
Easy
Local hydraulics shoppe
Get a straight fitting made of steel.
Braze (You could also use silver solder and a blowtorch) the nole up in the middle.
Drill a small hole thru the middle.
I didn't bother making restrictor..Mine is just a straight fitting without restriction.
the really neat thing is you can install with a deep socket even after the engine is hung.
Frank
03-11-2008, 05:41 PM
Super Moderator
I concur with Frank--- use a straight steel fitting and silver solder it shut, then drill with a number 60 bit. Been doing it for years, and it works fine.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
03-31-2008, 10:07 PM
816
Jeff,
Is this what your looking for? If so, I found a couple....
Regards,
Brett
Bonaco, Inc.
brett@bonacoinc.com
