Old 03-09-2008, 04:16 PM
Reddsky1 Reddsky1 is offline
Default Panel Markings
This may be a real simple question, but how do you mark your panels with the appropriate labels. Do you use decals or stencils. Most everything on the panel has to be labeled ie. fuses, gauges, annunciator lights.
What is the best way,
Thanks for any help.
Reddky1
RV-8 tail finished, waiting for the wings
Old 03-09-2008, 05:12 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Lots of folks use a "P-touch" label maker.
http://www.brother-usa.com/ptouch/wh..._whatsapt.html
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-09-2008, 05:21 PM
AltonD's Avatar
AltonD AltonD is offline
office max PT-2100, $70
it was on sale a month ago for $40. Can you believe that?
I used the 3/4" tz tape. clear with white letters.
I had to go to office depot for the tape. They have the same machine, but it is $80 regular price.
It connects to the computer usb. I loaded their software. My swithces are on 7/8" centers. The software pops up with a ruler above the tape. I laid out my label, printed once, made a couple of adjustments, printed a second time, done. Plus, you can save the layout for changes later.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 03-09-2008, 06:03 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up Overlays
Another method is to make overlays with the labels on them.
The overlay is held on by the nuts on the switches and/or breakers.
This was just made for me by these guys...
http://engravers.net/aircraft/custom-placards.htm
My panel should need no labels or engraving on it... they are all on the overlays.
Lighting switches are engraved rockers - sort of "self labelled"....
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-09-2008, 06:21 PM
Mike S's Avatar
Senior Curmudgeon
Good folks to deal with, they did my switches also.
Satisfied customer for sure.
I like the overlay idea, thanks
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 03-09-2008, 06:34 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I made full page decal sheets (including spares) on my computer's inkjet printer. Used Avery full sheet clear labels, and then sprayed clear coat from a rattle can over them --- before cutting and attaching to panel. Every letter on this panel including passenger warning and other colored labels are done this way. Makes it easy to make changes, and sizing for switch locations.
L.Adamson --- RV6A
http://img204.imageshack.us/img204/7...reducedwv2.jpg
Old 03-09-2008, 07:47 PM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
Default Try this
http://www.vansairforce.com/communit...ad.php?t=23897
As you will read in this thread, the DecalPro system was recommended by several RV builders. I got it and after some futzing around it produced VERY nice results.
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 03-09-2008, 07:50 PM
Jamie's Avatar
Jamie Jamie is offline
As mentioned above, I used a p-touch label maker. You don't need a fancy one. They all seem to print about the same sizes, etc. I got a fancy one and used the PC design software, which apparently works on the less expensive models as well.
Also, be sure to have your label maker ready for your DAR inspection. You can get gigged on things you didn't think needed to be labeled. For example, I got gigged on my throttle, prop and mixture controls not being labeled. It was no big deal though, 5 minutes later and I had three little labels on there.
Old 03-09-2008, 09:33 PM
Thanks to everyone for the great Ideas.
Do most builders spray clear coat over the labels??
Reddsky1
Old 03-09-2008, 10:11 PM
AltonD's Avatar
I thought about the clear coat, but decided not to. It takes about 10 seconds to print new labels. Also, I wanted to keep the semi-gloss finish, not a gloss finish.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
