Old 03-08-2008, 09:25 PM
Top_prop's Avatar
Top_prop Top_prop is offline
Default Stupid Newbie Question
Howdy!
Been poking around here a little and have a couple question about the rules for building...
I see partially completed kits available, and offers for parts/engines stripped out of wrecked planes... how does this fit with the requirement to log the work and complete atleast 51% of the construction? Are their regulatory pitfalls of buying somebodies partially complete kit? I know there could be construction quality issues.
Thanks for your time.
Tom
I Timothy 2:1-2 I urge, then, first of all, that requests, prayers, intercession and thanksgiving be made for everyone-- for kings and all those in authority, that we may live peaceful and quiet lives in all godliness and holiness.
I Thesalonians 4:11-12 Make it your ambition to lead a quiet life, to mind your own business and to work with your hands, just as we told you, so that your daily life may win the respect of outsiders and so that you will not be dependent on anybody.
Old 03-08-2008, 09:44 PM
craigvince's Avatar
craigvince craigvince is offline
Lightbulb No such thing....
Welcome Tom!
First, and most important: There's no such thing as a "Stupid Newbie Question". In fact, your question isn't one I'd even expect from a newbie because it requires a great understanding of the spirit of the 51% rule to even think to ask that question!
Second, and still important: There certainly are implications to the rule when you buy someone else's already started project. Hopefully one of the DARs we have on this forum will pitch in and answer better than I can. As for engines and parts from other aircraft, you shouldn't have any problems, assuming you are the one to install them in your aircraft.
Old 03-08-2008, 09:56 PM
mannanj's Avatar
mannanj mannanj is offline
Default Question
Tom:
First of all I love your quote.
I think that if you can honestly sign your name to an affidavit that you have completed 51 percent of the work, then you can get credit for building the airplane and recieve credit as manufacturer of said aircraft.
If you can't, THEN if you can claim credit for your portion along with the portion built by the previous owner and list both as the builders, then you can get an airworthiness certificate.
At that point you would not be able to get credit for being the manufacturer of the aircraft and therfore you would not be able to do the annual Condition Inspection sign offs. That would have to be done by a certified A&P or an A&P with Inspection Authorization.
If I am wrong; Mel et al hopefully will correct me.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 03-09-2008, 06:30 AM
pierre smith's Avatar
Default 'nuther .02..
Mornin' all,
Essentially, the aircraft must be amateur-built and the guys above are correct. The "spirit" of the rule is that the airplane be amateur-built and whether or not you did it all is not that important since the previous owner was also an amateur. A good example is an airplane built by 30 high school kids and their teacher "for educational purposes" as has been done. Only one of them can sign that it was indeed amateur built but it will still fit the "spirit" of the rule.
Wait for Mel/Vern..??
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-09-2008, 06:51 AM
Mel's Avatar
Mel Mel is offline
Actually all can sign that it was amateur-built. Only one can apply for the repairman certificate. As long as you can show with pictures and builder's log that it was indeed amateur-built, the airworthiness certificate is not a problem.
As far as the repairman certificate, you need to show that that you were the primary builder and can effectively perform the annual condition inspection.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-09-2008, 01:13 PM
Top_prop's Avatar
Ya'll deliver!
Thanks for the insightful and complete answers!
