Old 03-08-2008, 06:51 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default ? on Nuckoll's Wig Wag System
More a question to satisfy my curiousity than anything else...
I just bench tested Bob Nuckoll's wig-wag flasher setup and have a question. On the drawing, Bob indicates that both the landing and taxi lights need to have a load on them for the wig wag to work. I took this to mean that the landing light and taxi light switches needed to be on along with the wig-wag switch. However, on my bench test I found that even with the landing and taxi light switches off, the wig wag will still operate independently.
Does having the landing and taxi lights "under load" mean something different than being "on"? For others who use this flasher, does yours work the same as mine?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-08-2008, 07:21 PM
vlittle's Avatar
vlittle vlittle is offline
Hi Steve.
I have a B&C mechanical flasher, and it only works if both lights are connected to it and power is applied. If either light burns out, it will stop working.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 03-08-2008, 08:44 PM
Originally Posted by vlittle View Post
Hi Steve.
Vern
Thanks Vern-
So should my flasher be working if both the taxi and landing light switches are off (but wig wag switch is on)? It does, so do I somehow have it wired incorrectly? (Actually, I like it that I can just flip the wig-wag switch for daytime flight without having to have the landing and taxi light switches on, but still wonder if I've done something incorrectly.)
Steve M.
Ellensburg WA
Old 03-08-2008, 09:34 PM
Rockyjs Rockyjs is offline
Yours are working just like mine. The landing and taxi light switches can be either on or off. You just need bulbs in the sockets and power to the flasher to get wig-wag.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
tomwebster's Avatar
tomwebster tomwebster is offline
I used the B&C flasher and one of their circuit diagrams.
Your functionality might vary depending on which diagram
you use. My lights wig-wag with only the W/W switch on.
In fact if the wig-wag switch is on, it doesn't matter
what position the other switches are in since they are
not in the circuit while in W/W mode.
My W/W will also stop if a lamp burns out.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
Old 03-09-2008, 12:11 AM
vlittle's Avatar
Originally Posted by alpinelakespilot2000 View Post
Thanks Vern-
My switch arrangement is such that I have 3 switches: taxi, landing and wig-wag. I have to turn the taxi and landing switches off for the wig-wag to work, otherwise, the flasher buzzes.
Why three switches? My setup is that if the wig-wag flasher fails, I can still turn on the landing /taxi lights.
V
V e r n. ====
RV-9A complete
S-21 wings complete
Old 03-09-2008, 12:35 PM
Sounds like Tom, Rocky, and I either are following a different wiring scheme or we have a different flasher, since none of us need to have the taxi and landing light switches on to allow the wig-wag to work. (I'm using 3 switches as well, Vern... two 1-3's and the 2-whatever that Nuckoll's indicates on the wiring scheme.)
Re: the noise... my flasher does make a pretty loud (turn signal-like) clicking when it's operating, no matter which switches are on. I'm assuming that this is normal (?), nothing to worry about, and that I won't hear it with the engine running.
Steve M.
Ellensburg WA
Old 03-09-2008, 04:34 PM
vlittle's Avatar
Here's a pic of the flasher and the schematic that I am using. It should be self-explanatory.
This configuration only has one switch between the power and lamps for ON operation, which is what I want for reliability. The FLASH switch only operates properly when both TAXI and LANDING switches are OFF.
Vern
V e r n. ====
RV-9A complete
S-21 wings complete
Old 06-25-2008, 12:16 PM
Leslee Leslee is offline
Default Wig Wag and landing light control
I just installed a device called a MaxPulse in my plane. It was a no brainer. And talk about control for wig wag and other functions. This device will handle two circuits at 10 Amps each an is the size of a Rheostat. No heat sinks, no other packages to mount - Just the device itself. Go take a look at it. You can find it serveral places on the web. Here is one http://www.maxpulsemaxdim.com There is also a Instrument Panel dimmer there called MaxDim .. no need to complicate this..
Old 06-25-2008, 01:17 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
$158 for the flasher vs about $21 for the B&C Wig Wag and even less for some off-the-shelf aftermarket automotive parts. The device looks nice though and has everything included, which is nice.
Is it harmful to momentarily light up a light while moving through positions?
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
