Old 03-07-2008, 03:09 PM
Steve Steve is offline
Default DAR Form 8050-88 question
Mel,
If I assembled my ECI Titan Kit engine, what entry is made on the "Manufacturer, Model and Serial Number of each Engine Installed" line on the 8050-88 (affidavit of ownership)?
Doe, John J., O320-B1B1N, 12345
or
ECI, O320-B1B1N, 12345
getting a start on the paperwork,
Steve
Old 03-07-2008, 03:56 PM
Craig-RV8a Craig-RV8a is offline
Default Engine
If you're going to put a data plate on the engine,,,, Whatever, you're using on your data plate;
Craig
Flying RV8a
JWY
Old 03-07-2008, 04:06 PM
Mel's Avatar
Mel Mel is offline
Craig is correct. It can be whatever you want it to be. It will always be an experimental engine.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-07-2008, 04:07 PM
Radomir's Avatar
Radomir Radomir is offline
I put ECI .. but looking online.. somehow that turned into Lycoming after paperwork reached FAA
Radomir
RV-7A sold
Old 03-07-2008, 04:26 PM
Mel's Avatar
Mel Mel is offline
What shows up on the final paperwork should be whatever was on the 8130-6.
Old 03-10-2011, 09:09 AM
panhandler1956's Avatar
Default Along the same lines...
I am filling out my 8050-88 right now and I'm stumped on the engine mfg, model, serial number line. I have what 'was' a Lycoming IO-360-A1A, but it doesn't have a data plate and it's definatly an experimental engine. What should I put down? I was thinking I sould call it whatever I want as long at it doesn't say Lycoming IO-360-A1A?
Help!
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 03-10-2011, 09:29 AM
Mel's Avatar
Mel Mel is offline
Default Yep!
If it doesn't have a dataplate, you can call it whatever you wish.
Old 03-10-2011, 10:48 AM
Default Thanks!
Thanks Mel! That's what I needed to know.
Brent Owens
Columbus, OH
N784DE S/N #82614
