Old 03-06-2008, 11:05 AM
CNEJR CNEJR is offline
Default Safety Trim Module
Got my new TCW Safety Trim Kit today from Steinair, looks good. Now does anyone have any great ideas on where to mount the module? I wanted to put it somewhere under seat panels, but haven't figured it out yet. Any ideas?
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
Old 03-08-2008, 10:12 AM
Caveman's Avatar
Caveman Caveman is offline
Default Firewall / floor tunnel
I messed around with mine and wasn't happy with it under the seat. I finally settled on placing it in front of the floor tunnel vertical section near the firewall down low, below where the heat comes in through the firewall. This way the harness wires all reached and it is in a serviceable location where I can adjust the speed of the unit by removing the cover. I've got it wired up and it all works as advertised. Be warned that I have no idea if cabin heat transmission will be an issue. There is about a 1" gap between it and the firewall and 2 or 3" below the plate that separates the cabin heat from the tunnel. I may insulate it but have not done so yet. This is in a 7.
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 03-08-2008, 12:53 PM
Bevan Bevan is offline
I'm planning to put it on the bulkhead forward of the instrument panel. I have a removeable panel, so maintenance should be easy if required. You want easy access to make the adjustments (such as trim speed) without too much difficulty
Bevan
RV7A wiring
Old 06-20-2008, 04:02 AM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default and on an -8
Anyone mounted one of these on an -8 yet? Where?
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 06-20-2008, 09:16 AM
ArVeeNiner's Avatar
Default On the seat ribs
I put mine on a seat rib in the same bay as the stick. I installed it with the adjustment screws facing up which puts the harness facing forward. I moved it far enough aft so that it clears the bottom of the stick. I used Rivnuts in two places to attach it. I'll post a photo soon.
See my other post on the location of the microswitch if you're not going with an airspeed switch. It works great.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 06-20-2008, 01:45 PM
RV8MW RV8MW is offline
DOES ANYBODY HAVE ANY PICTURES OF WHERE YOU MOUNTED THE MODULE IN A 8 WITH HAT SWITCHES ON BOTH STICKS? AND DID YOU USE TERMINAL BLOCKS IF SO WHERE DID YOU MOUNT THEM. JUST TRYING TO GET SOME IDEAS.
MIKE WARREN
RV8 N184MW RESERVED
TMX-IO360 REDGOLD,HARTZELL CS
CLINTON N.C.
www.mykitlog.com/mwarren
