Completed the raw subfairing yesterday and I took it out to the airport to make a test flight with it installed. It didn't happen because the fairing was actually hitting the tire on the left side. The angle is so small relative to the vertical plane of the side of the tire that it probably would have worked but I couldn't live with that so I went through a process of filing and trying until I got some clearance then reinstalled it for the flight. I was out of time by then so the test flight was put off until morning.
I took off at 06:00 just after the tower opened and before the sun rose over the hills to the east. The test went well in that there was no damage or unusual behavior of the airplane. I flew a triangular course with tracks of 000, 120 and 240 degrees at 6,000 ft density altitude. The test method is the U. S. Air Race Handicap procedure found at
www.usairrace.org and the National Test Pilot School spread sheet was used to mathematically eliminate the wind effect. My benchmark speed with this the "long wing" configuration is 174.3 knots but there are some small speed increase modifications that are not included in that number (cut off exhaust pipes to get the tips out of the slipstream and provide more direct aft flow of exhaust gasses, washers between the prop and aft spinner bulkhead to eliminate contact at maximum pitch and fine wire spark plugs) but the sum effect of these mods is a small fraction of a knot. The speed today was 175.4 knots which is a significant improvement. How much of this will be lost when changing to the faster short wing configuration is unknown but I expect to see 178 knots.
There is still work to be done, the metal alignment strips riveted to the inside of the front part of the new subfairing needed to be replaced with longer ones (done tonight), and the fiberglass has to be filled and painted. All in all it looks like a good racing mod for an RV-6A. It is probably no good for casual operation or landing on unpaved strips.
Bob Axsom
