Welcome to the RV addiction
Welcome Fallguy.
You are correct, there are no bad choices.
You are in the initial phase of decision making. Nosewheel v tailwheel, fixed pitch v C/S, tandem or side by side, VFR/IFR, engine choices and a gazillion other decisions. You will learn about the primer wars later.
The nosewheel v tailwheel debate is an endless one, and both sides make good points. It seems that you have decided to go with the nosewheel. You asked about resale value. Let me make the observation, perhaps others would not agree, that a nosewheel aircraft would be marketable to a wider range of pilots than a tailwheel aircraft. Your insurance company would also treat you better.
I am building an 8A, so I have some built in prejudice for that model. I have nothing against tail draggers, I own and fly a Taylorcraft L2 (tailwheel). I also like the tandem seating. Your wife may not agree. It seems that most wives prefer the side by side models. Actually, the wife will find that she has more room, and will be more comfortable, in the back of an 8 than beside you in a side by side model. If your wife is OK with the tandem, you are one lucky man.
Put seat cushions under your little one until she outgrows them.
Whatever RV you choose to build, you will have made a good choice. You will find that this website is a HUGE help in making your decisions, and in the building process. I benefit greatly from the advice and experience of fellow RV builders and pilots who share their knowledge here. You will also.
Welcome to the club.
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
