Old 03-04-2008, 10:33 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Default Vertical Power VP-50
I just noticed this on Vertical Power's Website: http://www.verticalpower.com/VP50.html
Looks like it has most of the useful features of the VP-100 at half the price. Anyone considering this?
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 03-04-2008, 11:09 PM
mlwynn mlwynn is offline
Default VP 50
Hi Rob,
I had looked long and hard at the VP 200 but just couldn't figure out how to stuff it in an RV 8 Panel. The VP 50 looks like a much more viable option, space-wise.
The specs list quite a number of potential inputs for circuit protection. There are only six switches on the front. Is the idea that you would use additional external switches for other functions or is there some sort of multifunction option for the switches?
Regards,
Michael Wynn
RV 8 Fuselage
Old 03-04-2008, 11:29 PM
RV10Rob's Avatar
Originally Posted by mlwynn View Post
Hi Rob,
It appears it'll accept external switches
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 03-05-2008, 07:40 AM
rvator51's Avatar
rvator51 rvator51 is offline
Hi Rob,
Regards,
Michael Wynn
RV 8 Fuselage
Hi Michael,
I installed a VP-100 in my wifes RV-4 and it works great. The switches on the front are totally programmable. You can put one or more functions on any of the switches. For example, you can use one switch as a main bus, another as an aux bus, or one switch for nav lights and strobes. As long as you dont exceed the max amps for that circuit, you can group the loads in a way that works for your aircraft.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
