Originally Posted by bullojm1
Also, what I have found is using the countersinking cage with an air drill always leads to chatter and some runaway holes. I exclusively use an electric (or battery) drill on a very low speed. That has given me excellent results.
I'll second that. It takes longer, and it's a pain, but it doesn't chatter.
And yes, I would use that part. For what it's worth, I did ruin and throw away a few parts using the same technique you describe, with the hole in the MDF. I subsequently quit countersinking over the table for that reason, and always countersink over free space where I don't have to worry about the tip of the countersink bit hitting anything on the other side of the hole and interfering with the cut.
Garden City, TX
VAF 2020 dues paid
