You can also use the fuel hose with a fabric/leather/naugahyde covering of your choice--------just cut a strip as long as the tube, half inch or so wider than the hose circumference, lay the hose slit up on the fabric, wrap it up and around the hose, tuck the edges into the slit.
Easier to do, than describe.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
