Old 03-02-2008, 07:33 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Short D-Sub Back Shells?
I was doing a little work on the panel today, and ran into a clearance issue with a D-Sub connector - there wasn't room for a standard back shell. I removed the back shell entirely for now - the wires are just fine, not being moved around, and stain-relieved with a loop - but I'd like to put some kind of enclosure on the connector. Does anyone know if there is a "low clearance", or maybe a right-angled back shell for D-Subs?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-02-2008, 08:02 PM
craigvince's Avatar
craigvince craigvince is offline
Lightbulb Side entry backshell
Try this ?
Available from Mouser, Part # 706-165X13419XE.
This is for the 9-pin, but they also have the larger sizes.
Old 03-02-2008, 08:48 PM
Ironflight's Avatar
Originally Posted by craigvince View Post
Your post said "S-Sub". Assuming you meant to type "D-Sub", try this:
Whoops - yup, "D-Sub" - dang spell checkers......
Thanks Craig, but those still look too long -I need something about half the length of a normal back shell, or I'll just go without - it's all behind the panel anyway.
Paul
Paul F. Dye
Old 03-02-2008, 09:07 PM
az_gila's Avatar
az_gila az_gila is offline
Smile A bit shorter...
Paul....I have the same problem with a Stein Dynon harness.
My Dynon D-180 37 pin D-sub connector is just about 2 inches long...
The best straight 37 pin one I could find on the Mouser pages is this one at 40 mm long.
http://www.conec.com/pdf/16K1A1078.pdf
Probably good enough for my RV-6A application.
Stein's guy also said that I could intsall it with no backshell, but like you, I prefer some support back there....
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
