Old 03-02-2008, 06:14 PM
dnimigon's Avatar
dnimigon dnimigon is offline
Default Tail Strobe Wiring run
Hi All
Building the RV-9 empennage and got to the point where I got to consider wiring for the strobe/tail light combo. I'll be mounting it on the lower portion of the rudder but would like to know where a guy should be running his wiring. I've got the wiring kit from Van's and it doesn't really show where these runs should be. I guess I'm asking where the wiring comes into it from the fuse. Any one with pics would sure help.
Old 03-02-2008, 06:24 PM
craigvince's Avatar
craigvince craigvince is offline
It will come right out of the tailcone on the fuselage, into the rudder. There is no prep needed during the construction of the empennage. Just don't do your lower fiberglass piece yet, since that's where the light gets mounted. I'm sure others will post pictures of how they routed the wire into the rudder.
Old 03-03-2008, 10:06 AM
dnimigon's Avatar
Default Thanks
Thanks. That's all I needed to know. Very simple and to the point. Why doesn't Van's tell you that in the instructions.
Old 03-03-2008, 10:30 AM
airguy's Avatar
airguy airguy is offline
There's a LOT of things Van's doesn't tell you in the instructions - wait till you get a little further along in the empennage. Lots of steps get left out and glossed over on the elevators, you're just expected to figure it out. I can't wait to see what the wing build manual looks like...
If (when) in doubt, put down the tools and study the diagrams very closely, that has saved my bacon a couple times already.
Old 03-04-2008, 07:05 AM
DaX's Avatar
DaX DaX is offline
I just started my wings and I can tell you this, there are no neat little check boxes by steps. The instructions are more paragraph style. There is a lot more reading the paragraph, then looking at prints for 30 minutes and visualizing.
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 03-04-2008, 07:44 AM
airguy's Avatar
That's about what I was expecting. Even on the elevators, following the directions explicitly would leave me with about 2/3 of the rivets not in place, half of it not deburred, and about 1/3 of the skin (and none of the spar/ribs) dimpled. At this point in the kit you're expected to just "get it" and do some (or most) of the steps without having to be told specifically to do so. You end up spending a lot of "Kumbaya" time with the manual and the drawings, and I spent probably 45 minutes yesterday dry-fitting all my elevator trim tab parts with my servo to make sure I understood exactly how it would come together before picking up any tools.
It makes me wonder if I'm going to get to the section on building the flaps and the manual will tell me "Examine the drawings and build as indicated."
Old 03-04-2008, 07:57 AM
Brantel's Avatar
Brantel Brantel is offline
Naaa, they help you a little more than that on the wings, its the fuse where they do that to you! Wait till you have to guess what raw stock to make a part out of to be sure you don't accidently cut up a long piece that will be needed sometime at a later date!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-04-2008, 08:21 AM
Jim Harchanko Jim Harchanko is offline
Some other things to consider: Where are you putting your tail strobe power supply? In the rear of the fuselage shifts the CG to the rear because of the long moment arm. I put mine under the seat floor pans and used shielded wire back to the strobe. Keep the strobe wire separated from the Comm antenna if it is mounted on the bottom of the airplane. I discovered Comm noise from the strobe even with shielded wire but as little as one inch separation from the Comm antenna terminal eliminated the noise.
Old 03-04-2008, 10:33 AM
morlino's Avatar
morlino morlino is offline
Building my left aileron was a disaster it took me a really long time and I had to drill out a bunch of rivets because I didn't do it correctly the first time.
After that experience, I took five minutes to translate the few paragraphs in the build manual into a list format (just hand written in my log notebook). I didn't really change the instructions, just the format.
My right aileron when together much more quickly and with no mistakes.
So before I started my flaps I rewrote the instructions preemptively and it seems to have helped a lot. It basically allows me to spend time studying the instructions and plans once before I start instead of doing it constantly as I'm building.
I don't understand why Vans writes step-by-step instructions in paragraph format?
mark
RV7 - working on wings (very, very slowly)
Old 03-04-2008, 04:57 PM
Ron B. Ron B. is offline
On our elevator trim tabs, the plans did not call out to dimple the close up tabs. We had the foam ribs glued in when we looked at the rivet layout and noticed countersunk rivets. Now, that was fun dimpling those holes. Seems to me a little more typing would save a lot of builders a lot of mistakes.
Ron
