For you electrical wizards out there-I ain't. Finished wiring the head of my RAC 205 Stick grip per Fig 1 plans-one stick, no relays. On the plans it says to wire the PTT normal open to normal closed #2 switch. Ok. Then wire common to PTT/radio. Problem-my radio/intercom has one shielded wire comming off of the intercom that I have connected to the 6 position terminal board mounted between the seat ribs. I have the wire on one connection/ring terminal, shielding on separate ring terminal. Where do I connect common from stick grip? What about the shielding connection?
2. I have a TruTrak ADI Pilot II A/P. want to use switch #4 on grip. A/P wire white/black connected to separate ring terminal on board. Common from grip switch to other side of this terminal-correct?
3. RAC wiring drawing says to run a single 12V power wire from grip head to source, and to also run (-) ground wire. To where and why? The A/P is a off/on momentary switch to engage/disengage the servos, and the PTT is a off/on momentary switch to negatively enable the radio, correct?
I hate wiring. Stein where are you when I need you?
Thanks in advance,
Mike H 9A/8A
