Old 02-28-2008, 07:48 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Question Backup oil pump/pre-oiler
I'm about to order a couple of Infinity stick grips for my RV-8 and Infinity are also heavily pushing a backup oil pump. I must admit that it sounds like a good idea, but is it worth the extra cost/complexity/weight? Is the risk high enough to warrant the mitigation? Is there anyone out there that is using one? Thoughts or comments?
Just trying to decide whether or not to add one to the order; they're not that expensive really, and if they actually improve the longevity of the engine (pre-oiler function) and avoid a disaster (backup oil pump function) then maybe I should go ahead with it. And no, I haven't fully chosen my engine yet, though there's a 95% chance it will be a mattituck IO360.
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 02-28-2008, 07:56 PM
Mel's Avatar
Mel Mel is offline
Default Are your cam lobes oiled by pressure?
The biggest problem with a pre-oiler is that the cam is the weak point in a Lycoming. The cam lobes do not get oiled by pressure. They are oiled by "splash" only when the engine is running. Therefore, unless you have Ney nozzles, running a pre-oiler pump will not oil the cam.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-28-2008, 08:50 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Default other options
Even though I have ney nozzles, I went a different route. Due to the above mentioned CAM shortcomings, I had mine coated to both absorb or hold oil and lower friction.
http://www.cradin.com/lubrication.htm
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 02-29-2008, 05:19 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default I thought about getting one too
I was tempted but then after listening to all the nay-sayers with regards to redundancy...i decided against it. It may help the engine but there are tons out there without it that do just fine and as for having a back-up, well, I only have one prop, one engine, one radio, one nose wheel, one path of fuel flow etc.
