Old 02-27-2008, 05:55 PM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default Engine Fittings Aluminum or Steel?
My new Superior engine is supposed to arrive this Friday. I am interesed in finding out about AN fittings for the engine. Do I use aluminum or steel AN fittings? I of course am referring to the various connections for Oil pressure, Oil Cooler, Fuel etc. Any chance that the engine already comes with the fittings installed.
I want to do the right thing so please give me your thought.
I would really appreciate any detailed help.
Regards
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 02-27-2008, 09:29 PM
Greg Arehart's Avatar
Jeff,
I recently built a Superior IO360 (on a 9A) and most of the fittings are installed when you get it. Those that are not are included in Vans FWF kit. Most are steel. I would wait and see just what you are likely to need after you get the engine and hang it.
greg
Greg Arehart
N 7965A
Old 02-27-2008, 09:35 PM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default fittings
Instering question.. The oil return fittings on all Lycomings are alum.
Most like steel for oil cooler to case. Vans has alum in the FWF kit. I have been using what is supplied. SO far so good.....I think ? it dosent matter.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 02-27-2008, 09:51 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Steel for oil lines
Based on the recommendation of a 25+ years aviation maintenance professional, I ordered steel fittings for oil cooler lines - both on the engine and on the oil cooler.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 02-27-2008, 10:23 PM
yakdriver yakdriver is offline
You can get steel AN fittings at the local hydraulic store also. About half the price of aircraft and they have shapes and sizes for everything.. Also speed shops/ catalogs have aeroquip hose and fittings again about half price for the same quality. (the fittings on the Van's hoses are the speed shop type). Pacific Oil Cooler says to never use aluminum fittings in oil coolers only steel. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 02-27-2008, 10:54 PM
frankh's Avatar
frankh frankh is offline
Default Half the price?
I thought they were more like a 1/3rd..either way your local hydraulics shoppe is a wonderful place to go and can make any hose your heart desires except you'll have to provide your own firesleeve for the fuel lines.
Frank
Old 02-28-2008, 01:39 AM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default The advice being...?
What was the reasoning provided, Rick?
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 02-28-2008, 04:08 AM
tinman tinman is offline
I read that aluminum on aluminum can gall the threads.
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
