Old 02-23-2008, 10:36 AM
N162RV's Avatar
N162RV N162RV is offline
Default Cool little voltmeter
Take a look at this voltmeter. At only $40 plus shipping looks like a good deal and stone simple. Only drawback is it don't look like it can be dimmed.
http://www.digitalmeter.com/cgi-bin/...=configspc.txt
Scott Frierson
Picayune,MS
RV6A 160HP
(Sold)
RV12 (sold)
Old 02-23-2008, 10:56 AM
flyeyes's Avatar
flyeyes flyeyes is offline
I've been using the LCD version in my RV-8 to monitor the main bus. Works flawlessly. You can use a dimmable post light with the LCD, or I think they will sell it with an internal backlight.
James Freeman
RV-8 flying
Old 04-10-2008, 02:01 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Default Autodimming
The DATEL DMS-30DR here is sunlight readable and autodimming.
http://www.datelmeters.com/cgi-bin/w...oltmeters.html
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 04-11-2008, 09:16 AM
AllanC AllanC is offline
I have something similar, but only in LCD, not LED. One thing I learned is that the unit may need to be protected from the charger current type, if the unit is monitoring and wired to a buss or battery. I understand that some of the modern pulse chargers used for AGM batteries actually pulse the voltage/current beyond the tolerance of small digital voltmeters, and they may need some protection.
