Old 02-22-2008, 09:39 PM
pvalovich pvalovich is offline
Default RV-8A Front Stick Length with Infinity Grip
-8A. Can't believe I missed this, but I did.
Wired the front stick with an Infinity grip. A huge bunch of wires that seem to be connected where intended and the stick firmly and properly in place. HOWEVER, I did the above while the panel was being cut and wired at Stark. Clecoed the panel in today and found gross interference with forward stick movement. Looks like I need to cut about 5 1/2 inches off to get it to clear the panel. So all the wiring is undone, the cable pulled out and the stick disassembled. Bummer.
But enought whining - removing nearly half a foot of stick seems pretty drastic. Am I missing something? What did you other -8/8A Infinity users do?
Old 02-22-2008, 10:28 PM
Ironflight's Avatar
VAF Moderator / Line Boy
It's not just the Infinity grip - it is not much taller than any of the other "fancy" grips - you just have a lot of stick to remove to get it to clear the bottom of the panel! Many of us had the stick bent with an S-curve to move it back a bit, but that doesn't really change having to cut it off.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-22-2008, 10:41 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
Smile More than one way to skin a cat
Well....it's too late for you but for the next guy or gal.......you could have just cut your stick in place without removing all the wires. I ran into a similar scenario (RV8 front stick and RV10 both sticks) and I did the following:
- remove the Infinity grip screws and let the grip hang 'out of the way'
- tape the stick in the area to be cut (don't want to scratch the paint)
- mark the stick and cut with a pipe cutter
- CAREFULLY (so you don't cut any wires) slit the cut-off section vertically with your dremel and a good cutoff wheel...you'll need to cut it on both sides as it's a little stiff to slit one side and pry it open. You can slide a piece of 'whatever' into the tube as you cut the wires to protect them.
- CAREFULLY drill the hole (move wires to the side as before)
- remove the tape and reinstall the grip.
If it takes you more than 15 minutes you did something wrong. For me...this was a LOT easier than removing the wire connector/plug at the bottom of the stick to pull the wires out. BTW....you can do this 'in the plane' or just unplug your wires and do it on the bench.
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
Old 02-22-2008, 11:09 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default Bent stick?
Since "rvwoody" is not doing bent sticks anymore, does anyone know who else is?
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 02-22-2008, 11:14 PM
Bevan Bevan is offline
Default Yes but....
If you cut the stick with the infinity wires still running down the center, and then slit the to be discarded piece as descirbed, how do you drill the almost half inch hole through the stick for the through bolt without damaging the wires? I did this on the drill press with a stepping bit.
I just removed the Infinity grip to shorten it. I had initially cut my stick to length, but it was still a little too long. NOTE. Once you cut the stick to length and drill that through-bolt hole, you can't just shorten it a 1/4" or so because you can't move the hole. You're committed to shortening it in increments of at least 3/4" at a time as the 1/2" hole is centered about 1/2" from the end of the stick.
Personally I wouldn't want to do excessive "slitting" either with a dremel or simliar tool in such close proximity to electrical switches because of possible contamination with fine conductive dust. YMMV
Bevan
The Infinity grip is very nice though and a very good value.
Old 02-23-2008, 08:04 AM
rv6rick's Avatar
Uh oh...I left that step off of my 'procedure'......edited same....thanks for pointing it out . You just move all the wires away from where you're drilling. The wires go around the plastic 'lug' of the grip so there is plenty of room to drill. Not a big deal and was a lot quicker for me. You can blow out any 'dust' with an air hose (AYK). As you say....YMMV.
Bevan
6 RV10's
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
Love my Pitts S-1S
Old 02-23-2008, 10:16 AM
chesaning chesaning is offline
Default Infinity grip
Where did you come out the bottom of your stick with the wires for best movement?
Old 02-24-2008, 04:28 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Post
Originally Posted by pvalovich View Post
......removing nearly half a foot of stick seems pretty drastic. Am I missing something?.....
To answer your specific question: While it is certainly true you do have to cut the stick down several inches to accomodate the Infinity grip, the installed grip itself will restore about 4 inches of that removed length. I sized the joystick length so that my thumb resting on the flap toggle switch will just clear the bottom of the instrument panel as I move the stick fully forward and aft.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 02-24-2008, 11:33 AM
tonyjohnson tonyjohnson is offline
How much of the stick did you end up cutting off in order to clear the bottom of the panel?
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
