  #41
Old 03-05-2008, 11:40 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Originally Posted by mike109g6 View Post
Speed shops, racing supplies, auto, racecars use these same LED type annuncuator lights/legend lights. Boats also use them.
Maybe so, Mike, but a NZ website search so far has turned up precisely 'zip'!! Unfortunately, with me working 7-days a week at the moment, I don't have the capacity to actually get out into the real world during business hours! If it isn't orderable (is that a word?) online it doesn't exist for me!
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 03-06-2008, 01:16 AM
CraigC CraigC is offline
Originally Posted by AntiGravity View Post
So does anyone know the specific make/model of these things?
http://www.mpja.com/prodinfo.asp?number=16990%20LE
I'm having a very hard time finding a local source for them, or even anything like them. Closest I've got so far is one with an integrated pushbutton switch over thirteen times more expensive! If I had the make/model I could narrow my search. I'd order direct but they want a US $100 minimum order and a bank transfer. Ok, I could work my way up to the hundred bucks I guess with some other bits and pieces, but a bank transfer means a trip into town and another $25 for some lady behind the counter to press some buttons on her computer, which I absolutely have a hard time with...
That is, of course, assuming they would reply to my emails. Which they haven't. Which doesn't exactly instill me with confidence...
Anti- These things are not that expensive here. I could buy what you need and mail them to you if you don't need them yesterday.
Craig C A&P/IA
Mesa, AZ RV-8 SerNo 82582
Wings/Fuse N18VA Res
Old 03-06-2008, 11:48 AM
Smile Cheers everyone
Thanks Craig, and everyone else that has contacted me. Its great that there is such a cool bunch of people out there willing to help out. Us overseas lot, especially from lil 'ol NZ, sometimes find the logistics of getting bits and pieces something of a frustrating exercise, and usually a very expensive one. I reckon I'll have 30% of my plane tied up in freight and 'extra' stuff I didn't need but bought because it is easy to order lots than keep ordering littles!
Jeff Preou
Old 07-09-2014, 06:57 PM
walkman's Avatar
walkman walkman is offline
Robert,
Master Caution is driven by my EFIS - anytime I have a message on the EFIS, this light alerts me. The ESS BUS light is on when I have the Essential Bus powered from it's alternate feed. And as you guessed, EXT POWER just tells me there is a voltage on the input side of the external power jack, so I know if I am connected or not.
Paul
Sorry to resurrect a dead threat. Paul I have a question on how you powered your ESS shunt annunciator.
I want to know when the switch is closed. That is, there is power via the E buss shunt. however, one cannot simply pull power off either side of the switch as there is always power on both sides of the switch UNLESS the master is off. That doesn't help me in the "left it on" scenario.
One though I had was that in normal switch open operations, the voltage on the ebuss battery side of the switch is about 1v higher than the main buss due to the diode, but when the switch is closed the voltage is the same as power is no longer flowing through the diode. this is independent of the position of the master
Is that what you did?
how did you make it work?
cheers
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 07-10-2014, 11:39 AM
krw5927 krw5927 is offline
cheers
I know I'm not Paul (if I was I'd be smarter and better looking), but you could always simply use a DPDT switch instead of a SPDT switch. Wire your buses as you normally would to one side of the switch, and then wire power to an annunciator light through the other, independent side of the switch.
Kurt W.
RV9A
FLYING!!!
Old 07-11-2014, 12:20 PM
walkman's Avatar
Doh!
Thanks!
Old 07-11-2014, 12:43 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Yup - DPDT - that's the answer!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
