Old 02-18-2008, 04:27 PM
Phil's Avatar
Phil Phil is offline
Default Rib Flange Deburring Tips - Anyone???
Does anyone have a secret trick to reaching the tight relief-spots on the rib flanges? I've been attacking these things with the shoe-shine technique and some emory cloth. But it's still taking me forever and becoming quite tedious.
Anyone have a special trick they use to speed up the process some?
Phil
Old 02-18-2008, 04:59 PM
Bruce's Avatar
Bruce Bruce is offline
Phil,
Try the scotchbrite wheel. Should take most of it off.
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 02-18-2008, 05:35 PM
Mel's Avatar
Mel Mel is offline
Default Practice...
Come on up here for practice. I think I have about 14 ribs left on the bi-plane to finish.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-18-2008, 05:45 PM
vlittle's Avatar
vlittle vlittle is offline
When I complained to Gus at Van's about the Slartibartfarst* thing, he said "don't waste your time. It's more important that you smooth the flange so that the skin fits smoothly over the nose of the ribs."
This is done with a bench disc sander or scotchbrite wheel. Sometimes the skin on the tabs gets pretty thin but he said not to worry about it.
Hope this helps.
*Slartibartfarst is the designer of Norway's fijords according to Douglas Adams.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 02-18-2008, 06:36 PM
Mel's Avatar
Mel Mel is offline
But my ribs will have fabric over them. Smooth edges become a little more critical.
Old 02-18-2008, 07:44 PM
Rick S. Rick S. is offline
Sears sells mini scotchbrite wheels that fit in a dremel. About an inch in diameter and maybe 3/16" thick. Worth their weight in gold...I have never found them anyplace else but Sears...You can cruise through a rib flange in about 2 minutes. Once they wear a bit they get even better...Loved those things...don't care to see another rib flange for a long time
Rick Sked
Old 02-18-2008, 08:00 PM
Phil's Avatar
Very cool. I'll head to Sears tomorrow and see if I can find a handful of them.
I've got the major portion of the edges under control with a die grinder and mini scotchbrite wheel (1" x 1"). Having one that's 3/16" thick might be the ticket.
The real problem is the area between each of the tab flanges. Those are a royal pain.
Old 02-18-2008, 08:24 PM
-goose -goose is offline
The fastest way I found for those relief notches was to go around them with one of those hooked swivel deburring tools to take of the edge, then clamp the rib in a soft jawed vice & give a quick smooth with the emery cloth - shoeshine style as you say. But I didn't try the dremel, that might be the go.
John Keen
RV-7 complete in Phase 1
Gold Coast, Australia
Old 02-19-2008, 06:32 PM
Phil's Avatar
Ladies and Gentlemen,
Let me introduce you to the coolest website for jobs EXACTLY like this. All aluminum oxide and made of various shapes and sizes. Deburring just got a whole lot easier.
http://www.widgetsupply.com/page/WS/...aluminum-oxide
Old 02-19-2008, 06:51 PM
rzbill's Avatar
rzbill rzbill is offline
Default 'nuff said
Bill Pendergrass
ME/AE '82
