Old 02-18-2008, 11:27 AM
Brantel's Avatar
Brantel Brantel is offline
Default Pushrod tubes in the Southeast?
I had a brain fart while cutting my aileron pushrod tubes in prep for mating my wings this weekend. I marked 65" in from each end and then added the 25/32 or whatever it was to that mark using a set of calipers. All was well until I cut the tube on the wrong line. Bottom line is that I got in a hurry and cut one to long and one too short by the fraction of an inch called out in the plans. If I had not marked two little marks on each cut, it would not have mattered but I cut to the left of the opposite cut line. I got one tube I can use and another that is short and cannot.
So, instead of paying Van's a fortune for shipping and waiting for two weeks to get a new tube, anyone know of anywere in the Southeast to get 6061-T6 1.125" OD x 0.035 wall seamless tubing?
ACS does not list this size on their site.
First screwup that required new parts since the Emp. I feel like an idiot!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-18-2008, 11:46 AM
TSwezey TSwezey is offline
Chances are you will pay a lot more going somewhere else besides Van's!
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 02-18-2008, 11:49 AM
tmbg's Avatar
tmbg tmbg is offline
did you try calling spruce and asking if they have it? they just might...
Ian
Old 02-18-2008, 12:47 PM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default All may not be lost
If you have not yet drilled for the threaded rod ends, then verify that you will have the edge distance first. I believe the holes are to be 1/4" from the end of the tube. Measure the inserted portion of the threaded rod end. Determine where the rivet line must be for edge distance and mark 1/4" beyond that. Then insert both ends to that mark. You'll probably gain a 1/4" or so. So now we're dealing with a tube that is roughly a half inch too short. Check for total length measurements from bearing center to bearing center for the rod bearings that go in the rod ends. If memory serves me correctly, those things are fairly long. You may be able to get another 1/4" off each of those. If so, you're done. If not, I would see if ACS or anyone has longer bearings. Probably cheaper and easier to get than the tube.
The other alternative (For others with this problem who may not be that far along) is to order it along with the fuse. Shipping probably won't even change.
Hope it works out,
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 02-18-2008, 12:53 PM
PaulR PaulR is offline
Default warehouse
Brian,
Ryerson -Tull is a warehouser of carbon, stainless and Aluminum. They list the tube as a stocked item. I use the facility in Birmingham. They list a site in Chattanooga. If all else fails you could call them. Another is O'neal Metals though they don't stock as much aluminum, they have more locations to pick from.
Good luck
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 02-18-2008, 05:59 PM
Jeff R's Avatar
Jeff R Jeff R is offline
I second vmirv8bldr's advice. Try it and if it doesn't work, then order a new tube with your fuse kit. This isn't something that you need until later anyway.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 02-18-2008, 09:00 PM
RV10 4JF RV10 4JF is offline
Sorry to hear about that screwup. I've been there a few times in carpentry work. Now what I do is once I measure and draw my cut line, I always mark a couple of x's on the cut side of the line.
JF
Old 02-19-2008, 08:53 AM
Brantel's Avatar
Fuse is almost built and ready to install wings and do rigging. Need these puppies now....
I have checked and it has proven a challenge to find this stuff East of the Mississippi so I am just going to buy it from Vans. I need several other items like the wing root fairings and some more stuff so it can hitch a ride with them.
Old 02-19-2008, 09:05 AM
jdmunzell jdmunzell is offline
Default Brian, Hold on before ordering!
Brian,
Let me check with my hangar mate to see if he has one. He has a flying -8, and I recall seeing another completed pushrod tube in the hangar. I don't know anything about that tube, but I will give him a call.
Jeff
-8 wings, finishing up
-8 QB Fuse just arrived!!!
Old 02-19-2008, 09:21 AM
dpansier's Avatar
dpansier dpansier is offline
Not sure if you checked with Metal Supermarket, I have been able to get odd items in a short time if they do not have it in stock
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
