Old 02-18-2008, 09:12 AM
prkaye prkaye is offline
Default tight grip clecos?
I need to get some clecos that will pull the materials tightly together when there is considerable spring-back (i'll need this for the forward skins to pull them tight against the longeron where it is twisted inward toward the front. I found these at avery:
http://www.averytools.com/p-851-temp...fasteners.aspx
Are there any other types of clecos (perhaps less expensive than those) that will do what I need?
EDIT - nevermind I found the "wingnut clecos" - this post can be deleted.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 02-18-2008, 09:40 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Try a search for Wing Nut Clekos. Cleaveland sells there here http://www.cleavelandtoolstore.com/p...sp?number=CLWN for $2.80 each. Check out Ebay for some better prices.
Personally, I didn't use anything other than normal clecos for the front of the longeron. Maybe I added a normal c-clamp to it -- there is good access to get a c-clamp in there for the extra pull.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
