Fuel Sensor Calibration, Resistive
I searched the threads but want to confirm with those using standard senders. I assume that the floats will be stuck to the top of the tank until you burn off some fuel. In my example, it appears to be about five gallons down, then things start indicating.
I have set up conservative at 18 gallons useable in my 6 per side. By luck or circumstance, by indicators show 13.5g when full, then start to move after 5 gallons or so are burned. Then they are more, or less, in sinc with my fuel flow and total as indicated on my EDM.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
